Alex B Posted July 1, 2014 Share Posted July 1, 2014 does anyone have an info on piper's 1320 grind cams?after duration etc.also any fettling required for fitting to a vvc head? (they are vvc solid cams) Link to comment Share on other sites More sharing options...
Martin R Posted July 1, 2014 Share Posted July 1, 2014 Alex, 1320 cams 268 degrees and 10.9mm lift. AFAIK no fettling required. I think you only need the fettling on 1444. Link to comment Share on other sites More sharing options...
Alex B Posted July 1, 2014 Author Share Posted July 1, 2014 Alex, 1320 cams 268 degrees and 10.9mm lift. AFAIK no fettling required. I think you only need the fettling on 1444. cheers for the info as always martin i couldn't remember if it was 10.5 or 11mm lift that you can get away with without some small alterations to the head. Link to comment Share on other sites More sharing options...
Martin R Posted July 1, 2014 Share Posted July 1, 2014 Email DVA to be sure. Also make sure you have the correct springs. I have no idea if you need uprated ones? Link to comment Share on other sites More sharing options...
Alex B Posted July 1, 2014 Author Share Posted July 1, 2014 yeah will give dave a buzz in the morning, theres a set of unused ones on ebay.hence looking into whats needed to to fit em. Link to comment Share on other sites More sharing options...
fentuz Posted July 3, 2014 Share Posted July 3, 2014 http://www.midlandslotus.co.uk/forum/topic/63030-solid-cam-conversions/#entry265587 Link to comment Share on other sites More sharing options...
Alex B Posted July 3, 2014 Author Share Posted July 3, 2014 http://www.midlandslotus.co.uk/forum/topic/63030-solid-cam-conversions/#entry265587 Cheers bill I knew someone had mentioned em just couldn't find it. The 1320's could be the answer to my current VVC woes. Link to comment Share on other sites More sharing options...
fentuz Posted July 3, 2014 Share Posted July 3, 2014 careful, the ITB kit desire will become very strong... Several people started with simple solid cam conversion and ended with tune VHPD type engine... Link to comment Share on other sites More sharing options...
