S2 Exige Brakes
Chris the 295 or 304/8 disks all fit straight on. The calliper is then spaced back with Ali spacers or stainless washers if you loose a spacer (or are tight).
The thickness of the spacers are determined using this simple formula.
(new Disc size - original disk size ie 288 ) / 2
So (295-288)/2=3.5 mm you would need 4 spacers.
You can buy slightly longer calliper bolts if going bigger than 295.
If going past 308, and 4 pots, you need to consider caliper and alloy wheel size, but if you are Exige then you should be ok.
  • Replies 15
