Martin R Posted May 28, 2014 Share Posted May 28, 2014 Im suprised anyone puts up with rattling pads. A bit of the buffer material has always sorted it for me. You only need one strip per pad. I think it goes on the top either side? Feel free to correct this if my old memory is playing up Link to comment Share on other sites More sharing options...
JonS Posted May 28, 2014 Share Posted May 28, 2014 I have CLs on the Exige front and back. They rattle like hell on the front but its a price worth paying for such consistent, progressive and huge stopping power. I always make sure the discs and pads are dried out after getting wet, so had no probs with moisture absortion either. Car does get pampered though and doesn't even know that salt exists, never mind ice and snow!! It is not just making sure they are dry, but that they are rinsed off with clean water to get any road salt off. Sorry to bleat on, but an exploding pad whilst heading to a hairpin in the wet on track is not something I would wish on anyone! Totally agree with the reviews of their performance though, they really would feel like they were pulling your face through your visor - really impressed me when they're nice and hot. Like Martin, the anti-rattle pads worked ok for me - I couldn't put up with the rattle doing so many miles. Link to comment Share on other sites More sharing options...
Martin R Posted May 28, 2014 Share Posted May 28, 2014 Dan, i will be interested on your thoughts on disc wear on the CL6? Have you put them all round or just the front? Link to comment Share on other sites More sharing options...
Dr H Posted May 28, 2014 Share Posted May 28, 2014 Im suprised anyone puts up with rattling pads. A bit of the buffer material has always sorted it for me. You only need one strip per pad. I think it goes on the top either side? Feel free to correct this if my old memory is playing up I'm hoping the stuff I bought will work buck looking at the thickness of it and the amount of fore and aft movement my pads have in the calipers I'm not betting on it! Link to comment Share on other sites More sharing options...
Martin R Posted May 28, 2014 Share Posted May 28, 2014 Leigh, sorry if you are aware of this but it goes along the top edge of the caliper above the piston? They rattle when cold as they are high performance so are expected to expand due to the heat. I know you have different calipers in 4 pot but the anti rattle buffers are quite thick? Edit This explains it http://www.eliseparts.com/products/show/23/13/anti-rattle-brake-buffers/ Sorry if you already knew this but its not that obvious IMO Link to comment Share on other sites More sharing options...
Dr H Posted May 28, 2014 Share Posted May 28, 2014 Cheers Martin. That's exactly what I plan to do but they do seem to be very small! I've got the buffer stuff, just need to find the time to try and fit them and see if it works. My old 2 pots has some of these buffers on the front edge. Link to comment Share on other sites More sharing options...
Martin R Posted May 29, 2014 Share Posted May 29, 2014 Leigh, try one strip either side at the top. If that does not stop it, i see no reason you could not put it top and bottom? Link to comment Share on other sites More sharing options...
Phil S1 Posted May 29, 2014 Share Posted May 29, 2014 From my experience I would only fit the anti-rattle strips on the bottom edges of the calipers (as shown by the red arrows in the photos on the Eliseparts link). If you fit them on the top edges as well then I found that over time the brake pads (which are forced upwards under braking) will wear a groove into the anti rattle strip. As the brake pad thickness then continues to wear this groove starts to restrict the top of the pad from moving towards the disc, resulting in less effective braking and uneven pad wear. If the pads are really rattly within the caliper then I would fit 2 strips on bottom edges instead. Link to comment Share on other sites More sharing options...
Martin R Posted May 29, 2014 Share Posted May 29, 2014 From my experience I would only fit the anti-rattle strips on the bottom edges of the calipers (as shown by the red arrows in the photos on the Eliseparts link). If you fit them on the top edges as well then I found that over time the brake pads (which are forced upwards under braking) will wear a groove into the anti rattle strip. As the brake pad thickness then continues to wear this groove starts to restrict the top of the pad from moving towards the disc, resulting in less effective braking and uneven pad wear. If the pads are really rattly within the caliper then I would fit 2 strips on bottom edges instead. Good post Phil, i have never needed to fit 2 strips Link to comment Share on other sites More sharing options...
Dr H Posted May 29, 2014 Share Posted May 29, 2014 Some good advice there Phil, Cheers Link to comment Share on other sites More sharing options...
danwebster Posted May 31, 2014 Share Posted May 31, 2014 Dan, i will be interested on your thoughts on disc wear on the CL6? Have you put them all round or just the front? All round Martin, they've only been in a few days but I can see them wearing the discs already....the stopping power is outrageous though so I can live with the wear. Link to comment Share on other sites More sharing options...
