benny1235 Posted February 27, 2014 Share Posted February 27, 2014 I have a reverse cam in my evora through an Alpine system yet it has decided to show a white screen and nothing else so can not see behind me. Does anyone know what is wrong or had a simliar problem? Link to comment Share on other sites More sharing options...
Alex B Posted February 27, 2014 Share Posted February 27, 2014 not had any experience with reverse cameras myself however, standard trouble shooting for electrical issues...loose/bad connection?damp circuit board? fuse? Link to comment Share on other sites More sharing options...
chris_h Posted February 27, 2014 Share Posted February 27, 2014 I'd try disconnecting battery to give it a full reset or disconnecting and redoing cables. My mum had a similar problem on her jag, turned out water had got in the camera from being jet washed. Link to comment Share on other sites More sharing options...
P4N Lotus Posted February 27, 2014 Share Posted February 27, 2014 I'd say try a reset, like how Chris said, the system is just standard alpine, does your screen still work as normal? Sounds like its loose connection, were the any symptoms before hand? Or clean the screen try a hair dryer or towel maybe around the lenses water may have got in Link to comment Share on other sites More sharing options...
benny1235 Posted February 27, 2014 Author Share Posted February 27, 2014 It's sounds like its water Chris as it stop after I had the car cleaned by the local polish garage. Will a reset cure this? It should i just take it to a wiring expert? Link to comment Share on other sites More sharing options...
chris_h Posted February 27, 2014 Share Posted February 27, 2014 If your lucky it might dry out and start working again, otherwise you might need a new unit. The alpine one is about £100, but I believe you can use any standard reversing camera which you can get from ebay for £20 ish. Link to comment Share on other sites More sharing options...
