jonnyfox Posted February 25, 2014 Share Posted February 25, 2014 Just posted this on a few sites, lots of help so far from John JSR and Dan Webster....but just wondering if anyone's seen similar and what it may have been before ordering a new sensor. I'm fairly sure on start up prior to changing expansion tank I saw a high initial reading drop to normal but I'm now a little hazy on this point. From cold the temp rockets to 90, panicking I've messed around bleeding it with help from from Dan after likely inducing more air but now I'm very sure I have no air left to bleed but the temp still rockets to 90 initially from cold before dropping to normal, pipes all hot including heater, rad hot. Temp climbs normally to 92 fan on (that's what it's set at), 88 fan off. If I leave it 3 maybe 4 hours then switch on the ignition the temp reads 82 and will slowly climb to 90 odd the slowly drop back to 80 without even starting the engine! Any ideas, anybody experienced this before on a Toyota 2zz, still air in the system maybe or faulty sensor....I'm leaning towards the sensor now. Cheers Jonny Link to comment Share on other sites More sharing options...
danwebster Posted February 25, 2014 Share Posted February 25, 2014 Definitely look at getting the sensor changed if you're sure it's not getting any more air in. It shouldn't fluctuate like. Then bring it to our rollers....you won't believe the figures from what's been on it today Link to comment Share on other sites More sharing options...
jonnyfox Posted February 25, 2014 Author Share Posted February 25, 2014 Definitely look at getting the sensor changed if you're sure it's not getting any more air in. It shouldn't fluctuate like. Then bring it to our rollers....you won't believe the figures from what's been on it today Yea think so, I'm just curious if anybody else has had similar mate. Did Saturday go as well as the rolling road did today lol? Link to comment Share on other sites More sharing options...
danwebster Posted February 25, 2014 Share Posted February 25, 2014 Haha yep it went well! Link to comment Share on other sites More sharing options...
jonnyfox Posted February 25, 2014 Author Share Posted February 25, 2014 Cool lol :-) Link to comment Share on other sites More sharing options...
Martin R Posted February 25, 2014 Share Posted February 25, 2014 When you say rockets to 90 initially, how long does it take? Link to comment Share on other sites More sharing options...
jonnyfox Posted February 26, 2014 Author Share Posted February 26, 2014 90 seconds to 94 this morning and no fan came on, usually at 92 Then ran sweet a nut.... Link to comment Share on other sites More sharing options...
Martin R Posted February 27, 2014 Share Posted February 27, 2014 Something is amiss then. It cant reach 94 in that time unless there is no / very little coolant flow around the head? See what happens after the sensor change? I presume the sensor is on the head? Link to comment Share on other sites More sharing options...
jonnyfox Posted February 28, 2014 Author Share Posted February 28, 2014 Yep be here next weekend, should be fun. Link to comment Share on other sites More sharing options...
