I've Been Modding Again......
Dr H
Just before Christmas I embarked on another set of mods on the S2. Only just had chance to write it up.
So from the front of the car going backwards:
Remove front clam
Fit stainless steel towing post. Pretty easy job until you can’t thread in your towing eye. :wall. Turns out the post is threaded at the rear rather than front and you need an extra-long towing eye for it to work! Contacted the seller and pointed out this wasn’t mentioned, so he sent me one free of charge :clp
Fit silicone hoses to radiator – I can’t believe after all the money the car has had spent on it there were still the original rad hoses in there! I got them from JSF performance and they have a nice bleed screw setup that can be replaced it if seizes.
Fit new uprated heater box. Made by fezzasus (Tom). Uses an electronic heater flap and really works! Needs the dash removing to fit it so the controls can be wired up. Looks like this:
Direct fit to the k-series S2 and VX220. I now have a heater that puts out hot air. Drove in the cold and wind yesterday and was kept warm enough. With the roof on the cabin really heats up! The old radiator used to put out nothing but cold air.
Fit Mazda 323 7/8 inch brake master cylinder. It seems to be off the 1989-94 vintage car IIRC. Needs new holes drilling in the bulkhead as the screw holes are in a different place. TurboHarry (on SELOC) has fitted this to his car and it needed a 25mm longer push rod. So I bought one from him and it should have been a straight fit. However for some reason mine only needed to be 15mm longer. So after taking 10mm off the one harry sent all was OK on that front.
This needs new ends putting on the brake pipes as the seats in the MC are a different shape from those in the Lotus MC but you can reach the original brake pipes and bend them into position. Here it is fitted.
It also uses the original Lotus cap, and keeps the low fluid indicator functioning on the dash.
Brake bias valve was then fitted. Needed a modification to the centre tunnel but fitted quite nicely in the end. I didn’t want it sitting at the side of the centre tunnel and figured that it was out of harm’s way putting it in between the seats.
Needed a bracket fitting, main line cutting and connecting at each end. Then a hole cutting in the centre tunnel.
On to the rear brakes. Get new AP 2 pots from Junks. I obviously go all anal in an attempt to make them match the front 4 pots, so I got to work: Take caliper:
Grind off the ‘lotus’ logo
Disassemble caliper and send for powder coating
Reassemble and fit custom cut AP stickers
Fit brake adapter brackets (from a fellow Selocer in Italy)
and then calipers.
Handbrake spot calipers purchased from a chap in Italy. Direct fit for either a 288/290 disc and also does one for a 308 disk. Supposed to be direct bolt up for some reason mine needed shimming in the body. Laser cut shims (black bit is the brake caliper spacer that goes between the two parts of the caliper)
Fitted and set up.
Moving to the engine bay. Remove SC and inlet manifold and dismantle. Remove rocker cover. Port IM opening where the CC bolts up to it (remove about 3-4mm across the whole width of the opening. Quick note – the long bolts keeping the SC and CC bolted to the IM were not very tight at all!
Sent IM to be wrinkle power coated in black. Here’s a quick shot of it fitted, forgot to take one whilst it was off.
Whilst this was off, send the valve cover to be painted in wrinkle black.
Change (almost) all the engine hoses to black silicone (from red).
Fit bleed valve into the CC system near the core.
Reassemble and refit the IM and SC with a new thermal manifold gasket, and new SC belt.
Refit cam over with a Skunk 2 washer and bolt set.
Drain and remove fuel tank. Remove original fuel pump unit (currently only used for sender function) and replace with a VDO level sender. This needed a customer adapter machining which was duly done by ProAlloy.
Fitting this needs a thinner o-ring seal than the original or it’s too tight to fit. Fit 2 wires from the sender up to the dash behind the clocks.
Then run wires down sills from new oil pressure and temp senders Back up to dash. Replace this gauge (oil pressure and temp)
With this gauge (fuel pressure).
Fit wire to pin 24 of the ECU (this is a multiplexer that puts out about 24 channels of data from the engine etc.) run wire up to dash in cabin.
Fit USB cable to ECU, run through to cabin. Fit USB ‘socket’ to cut out in bit between seats.
I did a lot of the prep, cosmetic stuff and sourcing the bits but the vast majority of the mechanics were done by Gav at Unit 4 in Burton. He hit lots of little niggles and problems on the way and had the patience of a saint! Was supposed to take 2 weeks and ended up being 6! As ever he did a brilliant job!
So that’s the latest round of mods. Just waiting for a few more bits to do the next one! biggrin.png
  • Replies 29
Leigh - Amazing attention to detail!
Gav was telling me about your car and how much of it is bespoke, I bet you get a lot of pleasure when these 'projects' you undertake get completed.
Good work fella!
Mark
I wish I had your funds and time to lavish on my garage toy.
It's my only pleasure in life Steve! In all seriousness it does ost quite a bit but luckily we have a small mortgage, I don't spend loads on a daily driver (not monthly payments on a loan etc.) and I don't go out on the piss all the time. Mind you if I added it all up I'm sure I could have a very nice Aston or Fezza in the garage but they are all too common!
Good work fella!
Mark
Gav was a star - it really did try his patience. Loads of stuff that was supposed to be a straight fit wasn't and needed a lot of messing around with. Luckily Gav's attention to detail is almost as anal as mine. I enjoy having / doing stuff that is 'different' from the norm, even if it's just in a small subtle way.
Love it Leigh. How are the brakes now?
The calipers look awesome and I love the sublety and neatness of the bias valve control.
Brakes feel great. Pedal travel is back to original feel with just the 4 pots on the front and the original master cylinder it got a bit longer. With the 2 pots on the back it would have been even worse. The Mazda master cylinder is 7/8 which is the same at the Lotus AP motorsport one - it just costs about £150 less biggrin.gif I only have 290s on the back so actually don't seem to need the bias valve!. If you put 308s on the back I might need to use the bias valve to back it off - so that's another mod for the future. I fitted the valve and sorted out the centre tunnel Gav plumbed the brakes lines in.
Wow, nice list of mods?!
Sorry - it's already sold. I don't need oil temp and pressure on a gauge as my next mod displays all the info wink.png
Just make sure you put them back before his MOT otherwise he might notice they're gone!
bleh.gif borrow away Jonny!
Did think about this actually. Heater box is the same, master cylinder a lot lighter as it's ally as opposed to steel. 2 pots and handbrake calipers are actually lighter than the old pair of steel rear calipers.
