John FISH Curtis Posted December 1, 2013 Share Posted December 1, 2013 In a single garage without removing the rear clam? Going rate for a used CR box? Link to comment Share on other sites More sharing options...
jimbo07g41 Posted December 1, 2013 Share Posted December 1, 2013 Bit of a nasty job the first few times. Difficult on your own. The hardest part is putting back on. I used a jack and engine crane to line the box back up. You need to take the wishbone off and then turn the box by 90 degrees to remove. Can be done in a single garage with the clam on. Link to comment Share on other sites More sharing options...
russelld Posted December 1, 2013 Share Posted December 1, 2013 The higher you can get the car the easier it is. The gearbox mount is a PITA to remove & even worse to get back in. Good luck Link to comment Share on other sites More sharing options...
MilesH Posted December 2, 2013 Share Posted December 2, 2013 Yes, did it about a month ago in a single garage with the clam on. I was advised not to have the car too high as you need to get at it from the top when removing/refitting and support it with 2 jacks from underneath. It wasn't too bad a job and was definitely easier with two when re-fitting. Did the whole job and then found we couldn't select reverse! So it all had to come out again, Dan (Webster) came round to solve the internal gearbox issue and proceeded to drop and re-fit the box in half the time it took two of us to do it! It took us a full day (first time we'd done it) and Dan 4 hours. Link to comment Share on other sites More sharing options...
danwebster Posted December 2, 2013 Share Posted December 2, 2013 It's easy when you know how! Link to comment Share on other sites More sharing options...
