Steering
Alex B
Not a fault as such but I have a squeak coming from somewhere within my steering...
Any ideas?
  • Replies 8
Is it a squeak that occurs as you turn the steering wheel? If so, then it's likely to be the rubber grommet where the column goes through the bulkhead that needs a bit of lubrication. Well it is on a S1 anyway!
+1 Also make sure the pinch bolt is tight as well.
Luckily for the mouse population it wasn't a mouse.
It was a squeaking rubber bush on the front passenger side.
