Washer jets packed in on the second half of today's meet, and I not cannot clean my windscreen which is a little bit inconvenient.
I've checked the pipe work that's all clear as I rigged my compressor up to it and cleaned it all out.
Had a look on seloc for which fuse controls it had no luck.
So it's either he motor/pump or a fuse? Any pointers?
Cheers
Wash Bottle Problem
Started by Alex B, Feb 17 2013 03:49 PM
5 replies to this topic
#2
Posted 17 February 2013 - 04:00 PM
Is the washer motor turning?
Is the washer motor blocked with cr@p?
Jet nozzles blocked (use a pin to clean)
The main fusebox is located in the front services compartment on the passenger side, and is protected by a clear plastic cover. For access, remove the passenger side front body access panel followed by the radiator air deflector panel.
Fuse 4 - 15A
Fuse 4 - 15A
Call me "Fish"
Hand Crafted, one of a kind quirky jewellery, accessories, gifts & goodies, most with a vintage or retro feel....Belle and Olive
#3
Posted 17 February 2013 - 04:38 PM
Cheers for the reply fish, was the specific fuse I was after as couldn't figure out which one it was.
Nozzles are clear as I checked this with the air line and the pin method.
The washer bottle did have a lot of crap in the bottom which I have rinsed out. From what I can gather the pump isn't doing anything, however I don't think it's blocked as when you pull the out going pipe off it allows water to run through it(turned off)
scatty, on 06 May 2013 - 09:24 PM, said:
What goes on tour, stays on tour Alex. The first rule of the breakfast club.... :-)
#4
Posted 17 February 2013 - 04:58 PM
Not sure on the fuse for an S2 but, the stalk can fail and also the small pump on the bottle itself can die,especially if it gets full of cack,or finally the relay, if its the relay get yourself the VW article with variable speed intermittent, great mod . Not expensive or difficult to change.
Educated Criminals work within the Law
#5
Posted 17 February 2013 - 06:14 PM
Mine turned out to be wiring fatigued at the pump connector.
Well, the Elise is fixed but the A8 has gone to Audi heaven.
Old A8 now changed for new A8. More wafting, care of 4.2V8 fun...
View Garage
