Abs Fault
a7esk
Started with the warning light on dash checked it out at Silverstone Lotus now it's a new unit front clam off has anybody else had this issue mine a 2009 Elise 111R .
A120J6000F part number.
Eddie
  • Replies 17
Question could a wheel bearing cause a faulty reading on the ABS system?
Could it be a wheel sensor?
Yes that what I was hoping but if not its almost a £1000 to fix i did make contacted with Lotus that was a laugh don't care .
Today Checked all 4 corners for faulty wires all ok even checked fuses .
Eddie
I have heard of wheel sensors playing up when they get damp in them. Try resetting the ECU, can you disconnect the battery for twenty minutes on the R to do this?
Sounds strange that they diagnosis the most expensive part on the system first.
We had ABS light come on last year, dealer disconnected (I think LHF) wheel sensor sprayed plug/socket with WD40 and ABS light has only stayed on twice since for about 15min's of driving each time
Confirmed ABS unit failed needs replacing
Best place to buy one .
Both Lotus dealers confirmed it Dam .
Give Junks a call / U2U to start with? He may have a few ideas for a good second hand unit?
Is the current one a 2 channel or 4? Definatly not worth putting a 2 channel unit back in whilst it's all apart,
Yes goes to all 4 and manage to buy one today so next weekend work begins .
This unit does not normally fail was the first for a lotus dealer to see it happen to,
And lotus Engineer has only seen this once so they replaced the complete unit to fix fault as well .
Almost started but bleeding brakes with ABS unit calls for Lotus bit of kit to make the ABS work to get the air out off the system or can it be done with out this .
Bleed brakes then take the car out for a blast activating the ABS a few times & then re-bleed system again, this usually does the trick :)
