Brake Disc And Pad Upgrade / Replacement
#1
Posted 01 February 2013 - 10:52 PM
So what should I replace them with? Your disc and pad recommendations please.
#2
Posted 01 February 2013 - 11:04 PM
But I'd recommend the pagid rs42 pads. I think everyone has their favourites tbh. CL's are well liked also. Although folks have had problems with them, me included, if you let them run a tad low before replacing.... But they do have a cracking initial bite.....my pagids have been good though and I'd have again...
I had good advice from dave at seriously lotus. Again, always worth a call.
Bugger, just realised I'm in technical again!!!!! Stop leaving the door unlocked ian!! :-)
Edited by scatty, 01 February 2013 - 11:07 PM.
#3
Posted 01 February 2013 - 11:26 PM
http://www.seriously...kit-all-s2.html
That's the big jump most make and from a top bloke. Performance Friction are the track best IMO and for most LOT drivers (very dusty tho). Or go with Pagids but the squeak after a while..... I wouldn't touch CL's with a barge pole.
#4
Posted 02 February 2013 - 12:01 AM
I have pagid 42s and eliseparts aluminium belled disks good compromise between track and road
#5
Posted 02 February 2013 - 07:01 PM
#6
Posted 03 February 2013 - 10:02 AM
Jonny you dont have to spend all that to get four pot front brakes!
Use a one piece disc like in this kit and the price comes down
http://www.seriously...pgrade-kit.html
Or have a look here,
http://www.seriously...-brake-kit.html
One piece disc and Caparo 4 pot caliper. Really good cost effective upgrade for under £750 + vat. You can upgrade to alloy belled discs later when funds allow....
Best of all these will fit inside a standard Elise 16 narrow front wheel, so no need to by bigger wheels at the same time!
Here is the same caliper but in a kit with AP Racing 308 alloy belled discs
#7
Posted 03 February 2013 - 10:15 AM
#8
Posted 03 February 2013 - 10:33 AM
#9
Posted 03 February 2013 - 07:06 PM
#10
Posted 03 February 2013 - 09:18 PM
#11
Posted 03 February 2013 - 09:58 PM
#12
Posted 03 February 2013 - 11:02 PM
#13
Posted 04 February 2013 - 12:30 AM
I've 295 ali bells & CL5+ on the front and EBC ultimax & CL5+ on the rear, and (other than the annoying droaning of the ebc slotted discs under hard braking), I still want a bit more bite on the rear, the fronts are ok as they can lock all too easy. I like the CL5 pads, but some people have had problems with the pads breaking up when run low - although I haven't had this. But their cold, wet inital first bite is so much better than oem/mintex IMO - I've not tried RS pads.
Some ppl say that EBC discs and RS or CL pads all round is good enough for TD/racing, (maybe ali belled 295 fronts and 288 rears). From my experiance EBC discs and CL pads are a big improvement on OEM, (I like the CL5's). I'm tempted to try the new ebc sports discs on the rear as they have more carbon in the discs (better friction rate) and are quieter slots, so when I need new pads (might try CL6 rears), I'll get some new rear discs too.
Some of the discs Dave has pointed out may be lots better and have better bite, but then again you may get better value for money on ali belled new discs all round, new pads, and new brake fluid, rather than just doing the front. Have a look at your rear disks (are they worn too), decide your approx budget and give him a call to discuss your options.
I guess it depends on what you have to spend and what you want? TD's, Fast Road, normal road?
See if there is anyone that has a similar set up to what you are thinking of getting and ask them for a demo.
Edited by Numbnutz, 04 February 2013 - 12:40 AM.
#14
Posted 07 February 2013 - 04:14 PM
So next question is which alu belled discs can people recommend, and where should I have it done? My nearest place seems to be Mike at Sports Car services, can anyone recommend him? And do you normally buy all the bits and take them to the garage or get the garage to order? (sorry for noob questions!)
#15
Posted 07 February 2013 - 05:43 PM
I am pretty sure new hoses for an Exige will require the removal of the front clam. I have the same set up with Eliseparts alu belled disks and pagid 42s.
http://www.elisepart...elled-discs-s2/
If I had my time over again I think I would be buying the seriously lotus ones. they are cheaper than the eliseparts ones and they are left and right handed and have the correct cooling vane orientation for each side of the car.
http://www.seriously...rake-discs.html
both sell pagids
View Garage
