Diy Geo (Any Tips)
#1
Posted 05 October 2012 - 07:57 AM
After much faffing about I have set the ride height, next I will be fitting Eliseshop uprated toe links. as all of this has messed up the tracking I have been thinking about doing my own geo.
I watched this being demonstrated a long time ago when DIY garages was set up(the two poles and string method). I went to B&Q and purchased two poles and some nylon cord. I have mocked this up on the car but I cannot seem to get a good place on the front of the car for the pole to be attached.
For any of you that do you own Geo's have you got any tips or different methods of doing this.
Thanks Sheldon
#2
Posted 05 October 2012 - 09:02 AM
#3
Posted 05 October 2012 - 09:04 AM
#4
Posted 05 October 2012 - 10:52 AM
Sit your second pole on top of the rear diffuser ( mine is a one piece diffuser & this is at the correct wheel center height ) and put your strings from the front to the back pole.
Use monofillament fishing line for your strings, this stretches by about 20% and acts like a spring to hold your poles in place once attached.
Measure the distance between the poles when in position and make your two stings about 100mm shorter ( finished length inc loops ). Tie a loop to each end of the strings to slip over the poles. Because of the stretch in the fishing line when your strings are in place they will hold your poles in position. Simples !!!
You then need to move the strings on the poles so they are perfectly parallel, then move the poles so the distance from the centre of the front wheels to the string is the same at each side of the car, repeat this at the rear and you are all set.
With this method you can move the car back and forth to settle the suspension without having to re set the jig.
For camber hang a plumb line from a pole taped to the top of the clam, again use fishing line and a fishing weight ( 1oz bomb ).
I suggest you wear a disguise when going into the fishing shop.
Edited by russelld, 05 October 2012 - 10:59 AM.
#5
Posted 08 October 2012 - 02:24 PM
#6
Posted 08 October 2012 - 02:45 PM
Rest is as Russel says.
Also if you ask Dan webster nicely he may help you out. There is a guy I use in Sandiacre if you want a really cheap set up doing.
Edited by Stumason10, 08 October 2012 - 02:46 PM.
#7
Posted 08 October 2012 - 08:45 PM
jhall89, on 08 October 2012 - 02:24 PM, said:
All the equipment does is replicate the pole and string method. Guglielmi do know what they are doing but plenty dont. How many people do you see getting someone to sit in the car as ballast.
#8
Posted 08 October 2012 - 09:36 PM
It's not really a question of £s JSR have done my couple of geo's and it was fantastic, I believe that Guglielme is very good. I like working on my car the and i like to understand how the car fits together. There always seems to be some sort of smoke and mirrors around geos. I attended a session at DIY Garages a while ago with Walshy where the process was described and demonstrated.
I can't remember the guys name but he advised with practice you should be able to get accurate results. I would like to have a go and then get it checked.
Dan also did one for me ages ago, I will send you a pm as I still would like to get mine checked after
Thanks for all the replies
#9
Posted 08 October 2012 - 10:16 PM
either take readings and roll the car half a wheel rev and average the readings,
or measure the wheel run-out before you start (with a DTI) and try to find two points 180 degrees apart with the same reading, mark these with a spot of tip-ex and set them all horizontal for toe measurement and set them vertical for measuring camber.
#10
Posted 09 October 2012 - 08:38 AM
It's cheap and plasticy but is a clever idea. Manuals here that explain the process: http://www.trackace.co.uk/manual.html
We set the tracking on a bumpy bit of tarmac in the paddock and I've since checked it with poles and string and it was spot on.
#11
Posted 09 October 2012 - 09:49 AM
Thanks Tim I will have a look, I have seen another one that produced by a bloke on seloc and is supposed to be quite good but very expensive
http://bobvanm.brinkster.net/corbo.htm
Edited by stockhome, 09 October 2012 - 09:53 AM.
#12
Posted 09 October 2012 - 02:28 PM
#13
Posted 09 October 2012 - 03:29 PM
I'll lend you my gear if you want to have a crack at it yourself?
#14
Posted 09 October 2012 - 08:54 PM
#15
Posted 10 October 2012 - 04:13 PM
View Garage
