The engine seems to run with exactly the same characteristics now as it did back then when it went on the RR, it uses about half a litre of oil every 1000 miles and always has in the 2 1/2 years I have had the car. The engine does not smoke at all. The exhaust pipe exits have always been black and sooty, I put this down to the ECU overfueling the engine for safety reasons.
I recently did a compression test on the engine.
Here are the results :
COLD ENGINE : 12.8 / 14.0 / 13.8 / 12.4 as you can see 1.6 bar difference between no 2 & no 4 or 11.5% of the highest reading.
I'm not sure that I cranked the engine for exactly the same number of revolutions for each cylinder although it was close.
I made a much more concentrated effort for the second ( warm ) test.
WARM ENGINE : 13.6 / 14.2 / 13.8 / 13.3 a lot closer this time only 6.3% differential !
I was pleased with the above results.
The reason for my post is that my engine is leaking oil and I would like some advice on what my next course of action should be.
The leak is definitely engine oil and is coming from the joint between the engine and bell housing I'm 99.9% sure it's the rear engine oil seal.
I have had the seal replaced twice recently, the first time was when my gearbox came out for repair and it was done again shortly afterwards as it was leaking worse than before ( It has had a very slight misting of oil in this area for a long time so I decided to have the seal changed when the gearbox was removed ).
I have read as much as I can find on the subject and it seems that high crankcase pressure can cause the oil to be blown past the seal.
I have checked the steel gauze under the rocker cover as this has been sited as a possible cause of pressure build up if it gets clogged with sludge. The gauze is very clean and there is no sign of anything that would cause a restriction. The breather pipe which comes from the rocker cover and goes into the airbox is also clear so no restriction here.
If I have a problem and my engine is producing blow by would this be more than the crankcase breathing system can cope with thus causing pressure at high rpm ? If this could be the case is there any way that I can check or test for this ?
Any help or advice will be be much appreciated.
TIA Russ.
View Garage
