)I've recently purchased a full set of Nitron Street Series to fit to my S1.
My other half has had an operation and is at home convalescing and I am having to look after her. I can find a couple of hours (no more!) and a local garage to help me get the old shocks off, the new ones on and hopefully 'levelled'. I will have to wait for the Geo once my OH is better. The car is not going to get used in-between times.
To help get things set-up so that on-the-day-fitting is as simple as possible, can anyone give me any guidance on where I can pre-set the spring collars and bump/rebound adjuster to get the car off the ramp quickly and with reasonable driveability.
In case you missed it, it is a (standard 118bhp K) Series 1, it is still on its original OEM set-up, and the current ride height seems to be 140mm. I will take advice on new heights but if you do, translating that into a setting that I can do at home Wednesday night before dropping the boxes off at the garage on Thursday will be a massive help.
And one last thing, as a damage limitation thought, is there much chance that there could be a problem (e.g. siezed bolts?). I have new bolts to go on, but I am thinking, if there is any likelihood of a problem? If so, I need to think of a plan that allows me to get back to the OH on time.
Thanks in anticipation that someone in the community can and will help
Gary
View Garage
