DJWilma Posted August 11, 2015 Author Share Posted August 11, 2015 Good stuff, really glad you've got it sorted now. Need video of those runs...... ;-) Have lost my contour in the move so will purchase something and post shortly.....i promise Link to comment Share on other sites More sharing options...
DJWilma Posted August 29, 2015 Author Share Posted August 29, 2015 So sat in the car this morning and started it up all was good but the oil light stayed on. Stopped and got the camera Not a good sign......let it run for a minute and noticed a knocking sound.... Looks like the oil pump has failed and the top ends have gone. Will take the engine out next week and see whats what In three minds 1. fix the t series may need rods, crank and pistons at worst 2. Sell what i can from the T series and look at the 2.3 duratech turbo and start again 3. Break the car get some cash and do something else like a Maxi Clio 182 turbo or 306 gti-6 4x4 or......... However i intend to get drunk tonight......Beers Link to comment Share on other sites More sharing options...
Alex B Posted August 29, 2015 Share Posted August 29, 2015 Duratec turbo! Link to comment Share on other sites More sharing options...
DJWilma Posted August 29, 2015 Author Share Posted August 29, 2015 Duratec turbo! today it gets my vote Link to comment Share on other sites More sharing options...
jonnyfox Posted August 31, 2015 Share Posted August 31, 2015 Bugger! Link to comment Share on other sites More sharing options...
Dave Hardwick Engineering Posted September 1, 2015 Share Posted September 1, 2015 I can understand how you feel about the car. It's the point Mr Simba reached with the Lego Brick and why I ended up with it. I have been lucky so far with only slight niggles to overcome. I will be interested to see what engine you go for. Will you use the same turbo? I'm really impressed with the 28/67. Link to comment Share on other sites More sharing options...
DJWilma Posted September 8, 2015 Author Share Posted September 8, 2015 I can understand how you feel about the car. It's the point Mr Simba reached with the Lego Brick and why I ended up with it. I have been lucky so far with only slight niggles to overcome. I will be interested to see what engine you go for. Will you use the same turbo? I'm really impressed with the 28/67. Yep i feel the same, i love the turbo its awesome for what it is but always niggle in my head saying i should of gone EFR Should also have gone v band as well but on the whole its the best bit i bought after the DTA S80 If I wasn't such a man's man I would be crying now Cranks gone so have 2 of the 4 big ends, so needs a set of rods Oil pump inlet was indeed blocked.....but by big end so big ends look to have gone first but honestly have no idea why. Could of been low oil as light came on round a roundabout once, or mapping on big boost the engine stuttered So i think i will sell of the parts of the engine, will post in for sale and hope to recover some of the cash i have spent Then 50/50 on whether to admit defeat, or re start with another engine Duratec seems to be fav at the moment Sump has sludge and debris Engine is out and ready to be stripped, will try to sell what items i can Link to comment Share on other sites More sharing options...
DJWilma Posted September 10, 2015 Author Share Posted September 10, 2015 So today i managed to spend sometime with the engine, its with Tech1 Performance in Poole as i just dont have the time but more importantly the inclination to take the engine out. Good news is the head is ok So are the pistons And the Bores in the block But, this was in the strainer for the oil pump A Big End Shell So looks like my T Series adventure is done......Its been emotional, expensive and a failure......but was fun when it went Link to comment Share on other sites More sharing options...
jonnyfox Posted September 13, 2015 Share Posted September 13, 2015 Likewise buddy, I feel you're pain as you know already. Good luck moving forward ;-) Link to comment Share on other sites More sharing options...
DJWilma Posted September 21, 2015 Author Share Posted September 21, 2015 Had a drink last night after the Wales v Uruguay match and the long of the short is i woke up with a sore head this morning and confirmation the engine i had bought would be here on Tuesday ! WTF Its a 2000 mile RD9A ECOBOOST engine from the Focus ST will all the bits minus the engine loom and ECU (the most important bits) Plan is not to use the STD ECU or the Crate Engine PCM package but an Aftermarket ECU. Probably Syvecs GDI as they have done an ECOBOOST before and have a base map Good news is, so i am told, the ECOBOOST and Duratec share the same gearbox pattern and similar engine mounts Can change throttle body to cable, but may try to install a drive by wire throttle pedal Will chuck the GTX2867 on and upgrade the std injectors, only good for 300bhp so i am told. Link to comment Share on other sites More sharing options...
Dave Hardwick Engineering Posted September 21, 2015 Share Posted September 21, 2015 I converted from DBW to cable but Chris at EFI Parts in Runcorn has used a DBW module to connect the VX Pedal to the DBW Throttle Body. I seem to remember that Chris had also used a Syvecs ECU on some cars. Is there an exhaust manifold available or are you making one? Dave Link to comment Share on other sites More sharing options...
DJWilma Posted September 22, 2015 Author Share Posted September 22, 2015 Ford do a pedal for the Dbw on the crate engine package Spoke with Liferacing and they done a lot of ecoboost but the 1.6 and 1.0 and a loom is 1800! Manifold is a contentious issue as on the later engines which I have they are cast on the head. So its a case of having an adaptor to the GTX. Didn't see this as an issue as 400bhp has been made from these. Link to comment Share on other sites More sharing options...
DJWilma Posted September 23, 2015 Author Share Posted September 23, 2015 Engine arrived today has everything on it apart from the engine loom and top engine mount Link to comment Share on other sites More sharing options...
jonnyfox Posted September 23, 2015 Share Posted September 23, 2015 You work quick! Link to comment Share on other sites More sharing options...
DJWilma Posted September 28, 2015 Author Share Posted September 28, 2015 No point messing around The other reason i went for the 2.0 not the 1.6 ecoboost is its basically a duratec mzr engine The Gearbox bolt pattern is the same as a duratec, the 1.6 ECOBOOST uses a different pattern The engine mounts look the same as a duratec, and there are off the shelf adpator plates and engine mounts and this is a duratec Ecoboost Duratec Link to comment Share on other sites More sharing options...
