Steve J Posted March 4, 2014 Share Posted March 4, 2014 890kg? You should have got that Volvo lorry to move it's tyre off the scales Link to comment Share on other sites More sharing options...
DJWilma Posted March 4, 2014 Author Share Posted March 4, 2014 Yeah its taken a week but I have realised I actually like em tubby Link to comment Share on other sites More sharing options...
DJWilma Posted March 9, 2014 Author Share Posted March 9, 2014 Arrgghhh on way to skydiving lovely 65 mile cross country blast....tweaked the shocks last night so was loving the drive.. But first thing reversing out the drive and drove into neighbours car as an idiot The the innovate lambda sensor just stopped working so chucking in fuel, common I am told Then 30mph through a village heard a thud, rear view was a pot hole and car went light at the rear. Got the tyre weld out, just came out two big holes ffs So car is parked up, and couldn't find wheel nut adaptor to undo wheels and will get her recovered once I have finished jumping....if I survive http://gallery.seloc.org/albums/userpics/48468/20140309_084324.jpg[/img Link to comment Share on other sites More sharing options...
DJWilma Posted April 2, 2014 Author Share Posted April 2, 2014 Works mental so not had much time on my hands but purchased these, probably the most extravagant thing i have ever bought Carbon Fibre side scoops but they look good even if stevie wonder fitted the driver side one AFR gauge is back quick work from Grant at http://www.gb-ent.co.uk as usual and all back up and running Got to drive the car yesterday, shame it rained but at least its done some miles again 140 miles on a tank of 33 litres (20mpg which isnt too bad as most has been point and squirt). She is quick but has a little bump steer problems, 70mph on slight RH turn and the front was moving....assume dampers so will tweak these Exhaust is blowing though suspected down pipe so will have to check it out on the weekend, its never ending But, main fuse blew again. And this time i know why, it was loose in the engine bay and was earthing on the block. So its been wrapped and stuck to the clam shell.....so shouldnt happen again time for a track day soon though Link to comment Share on other sites More sharing options...
jonnyfox Posted April 2, 2014 Share Posted April 2, 2014 Love a bita'bling Link to comment Share on other sites More sharing options...
DJWilma Posted April 4, 2014 Author Share Posted April 4, 2014 Love a bita'bling oops had enough of work so had a lazy day at home, and got a surprise when i went to open the drivers door this morning before my sea swim Looks like the grill has come loose, broken the cross member and ripped out the self tapper at the top....then snapped off at the rear lug....so if anyone has a spare RH side CF side pod let me know FFS I was doing some high speed testing, on a private road, and didnt hear or notice it but full throttle (little clutch slip) and 6000rpm car was still pulling Looked at the exhaust and the turbo to downpipe had two bolts in it, school boy error but looks like the bolts are a few mm too long so they went tight but were holding. Have ordered some new studs and nuts so will try and get it finished. Eased off the shocks on the front and it rides a lot better with no bouncing Also played with the traction control and launch, now that was fun 20% slip 3500rpm a little sideways and hit the rev limiter in first a heart beat later. Cant wait to get some sticky rubber and get on a 1.4 mile Link to comment Share on other sites More sharing options...
DJWilma Posted April 14, 2014 Author Share Posted April 14, 2014 Thanks guys Well insurance is due in 2 weeks, been a whole year on the road and only 786 miles......not enough But car has been with a friend to have the clam repaired, and stickers added (thanks BobvanM), the rear diffuser painted plus a polish. Have a little paint reaction on the drivers side under the pod so will get that done soon..... Also got my 1275GT out of storage and on the drive so will be fitting a turbo k with 200bhp to it soon....i hope Anyway went looking for the exhaust leak, looked at the turbo to down pipe and very strange but all the bolts were too long for the threads. Good 5 mm and only being held in with one tight one. Replaced all the studs with proper high temp items and proper nuts. Lowest one was a bugger 1/8 turn each time..... Started the car up and exhaust blow was still there, hand in and found the turbo to manifold only had two bolts in on the right hand side......ran out of the proper nuts but will get some tomorrow and take it out Was hoping to get to Castle Coombe on the 22nd April with LOT Link to comment Share on other sites More sharing options...
DJWilma Posted April 20, 2014 Author Share Posted April 20, 2014 At last i have some time and get the camera in the car, and the heavens open Luckily i had a chance to set up the launch and Traction control settings Standing Start 3500rpm dump clutch 100% throttle and it does slip but considering the conditions i am fairly happy it didnt swap ends Then rolling 2nd gear full throttle and happy with the results, till the clutch slipped at the end Link to comment Share on other sites More sharing options...
jonnyfox Posted April 24, 2014 Share Posted April 24, 2014 Come on chop chop track day season is up and running ;-) Link to comment Share on other sites More sharing options...
DJWilma Posted April 26, 2014 Author Share Posted April 26, 2014 Come on chop chop track day season is up and running ;-) I know i know, been a member of LOT for 18 months and not been to one of them.......bad lotus owner Link to comment Share on other sites More sharing options...
DJWilma Posted April 27, 2014 Author Share Posted April 27, 2014 Have had Man Flu and a funeral this week so not had much chance, but managed to wire the Lambda Sensor in properly, but have a loose connect on the 0-5v feed to the DTA so need to check this. Also the fan knob fell off when i put my foot down, then rattled around so had to stop Then took it out for a spin today, still awaiting on the Clutch to grip it is getting better but and got the camera on forward facing. The sound for some reason is very quiet to need to re-check this too Link to comment Share on other sites More sharing options...
DJWilma Posted May 5, 2014 Author Share Posted May 5, 2014 What a lovely weekend perfect for roof down motoring, especially on my route to Swindon Sunday morning at 7am lovely country roads quiet traffic and even better the clutch has started allowing full throttle in 3rd and 4th So imagine my mood when 3/4s of the way and full throttle blast and rattle, then oil smell Drove at 2500rpm in fifth and the rattle started to get worse. Then it wouldnt tick over ! Managed to nurse it to work and let it cool, started again and it rattled, sounds like the big ends have given up. No idea why engine seems to have oil pressure 60psi is showing, however it doesnt change with Revs (assumed dodgy sender) So it spent the night on the back of a truck, again ! Worryingly i am expecting the worse and googling 2.2 t series...........hmmm Link to comment Share on other sites More sharing options...
jonnyfox Posted May 6, 2014 Share Posted May 6, 2014 Sorry to hear that, keep the faith though its a cracking project. Link to comment Share on other sites More sharing options...
DJWilma Posted May 10, 2014 Author Share Posted May 10, 2014 Sorry to hear that, keep the faith though its a cracking project. Will see what happens when the sumps off, but it will be up and running soon Link to comment Share on other sites More sharing options...
DJWilma Posted May 13, 2014 Author Share Posted May 13, 2014 Right looks like i have a PlanWill be replacing the engine with another forged T series, i was going to try and make a short stroke 86mm by 86mm bore engine but the forged cranks were on a 12 week lead time and would of gone for bigger valves and billet cams and it all got very expensiveHope to pick the newly built engine up next week, will post specs when i have it Link to comment Share on other sites More sharing options...
