Big Power For The Lego Brick!
MrSimba
Subframe now in place.
The timing wheel on the crank and failed bolts that fasten it to the crank. A new toothed wheel and fasteners were used.
Wishbones etc shot blasted and ready for painting
Standard engine loom removed, I made a new custom loom that plugs into the OE loom.
I also moved the relays and fuses from the boot into the cockpit to facilitate removal of the rear clam in future.
Also shown is the Adaptronic standalone ECU
I made a swirl pot to feed the high pressure pump (Bosch 044)
I fitted a Quaife ATB Diff to the box to aid traction.
Suspension refitted having been refurbished.
Dave
  • Replies 123
  • 3 weeks later...
Just had a good look at the power curves and its pretty much the same as my T series with the same GTX2867 so i am happy
402bhp at 23psi
But i also have the flat power curve from 6k to 7k
Very happy with my turbo spools quick ish, but does come on strong at 3000 - 3500 rpm
