MrSimba Posted September 9, 2012 Author Share Posted September 9, 2012 Update? All very much underway! Started by removing the LET engine and cutting an inspection hatch in so if any work needs doing in future on the 'hot' side its not an engine out job Then fab'd an inspection hatch out of nimus that can be removed in about 30 min (and 29 min of that is taking the seats and back panel trim out!!!) And with heat shielding everything else was done! looks overkill but the turbo / manifold that close to the firewall and 1000'c is very quickly reached melting everything in its path, heat is the real reliability killer on these builds so wanted to really address it So spent today building up the LEH engine and fitting it... And now its finally starting to look like a car again! Lots lots more to do yet but its got to be finished for next weekend... No Garrett turbo pics yet as that not fitted! Amazing how when you take things apart you just find jobs that need doing! My car is intercooled & chargecooled but today I've made sure every bit of air going into my IC now goes straight through and straight out again, and its spending time doing these jobs along the way that slows everything else down!!! But it WILL be done for the weekend!!! Mapping at CS on the 19th Link to comment Share on other sites More sharing options...
mambosasa Posted September 11, 2012 Share Posted September 11, 2012 Amazing. Excellent work. Link to comment Share on other sites More sharing options...
jonnyfox Posted September 12, 2012 Share Posted September 12, 2012 Looking good my evil friend! Link to comment Share on other sites More sharing options...
stockhome Posted September 13, 2012 Share Posted September 13, 2012 Looking good cant wait to see it finished Link to comment Share on other sites More sharing options...
MrSimba Posted September 13, 2012 Author Share Posted September 13, 2012 Really starting to come together quickly now Which is good as it's got to drive to Norfolk next Wednesday for mapping! Knew cutting that hatch was a good idea! Link to comment Share on other sites More sharing options...
MrSimba Posted September 19, 2012 Author Share Posted September 19, 2012 Well today was booked for mapping at Courtenay Sport in Norfolk but since everything went back together on Sunday the engine refused to turn over We tried everything Sunday night till 3am, Monday night till 4am, and on Tuesday we called it a night at 10pm and decided we were just not going to make it for Wednesday. So... tonight without doing anything we've not already checked it started!!! and then threw and EML...! P0115 which is on the coolant sensor, and it also threw a P0100 (the MAF on the same circuit) so spent tonight checking the continuity of the wiring and think we've now found the fault so am a lot more positive about it now Re-booked the mapping for Oct 24th as that was the next available date and it i's not sorted by then I'll be reaching for a box of matches... Anyway I know you like a bit of bling & Carlsberg don't do heat shielding but if they did... Link to comment Share on other sites More sharing options...
scatty Posted September 20, 2012 Share Posted September 20, 2012 Bad news about not getting it mapped. I bet you could have cried. At least you have sorted the problem. Link to comment Share on other sites More sharing options...
MrSimba Posted September 21, 2012 Author Share Posted September 21, 2012 Bad news about not getting it mapped. I bet you could have cried. At least you have sorted the problem. Bad news & a pain in the arse yes! But definatly no tears!!! Big project there is always going to be a few hiccups along the way just got to get it all sorted, thought we had be its still being intermittent with the electrical gremlins so some way to go still with it yet! Be all good in the end tho!!! Link to comment Share on other sites More sharing options...
MrSimba Posted September 21, 2012 Author Share Posted September 21, 2012 Well the project's taken a little twist... DG's triple checked the wires , connectors, earth, re done most of them and still nothing so it's the ECU that's playing up No point really putting an OE back in so this week DG's putting and an Adeptronics 'standalone' fully mappable ECU with cable throttle in to be mapped by Chris @ EFi So slight detour from original plan but know the car will be all the better for it so in the long run.... Or that's what I keep telling myself! *anyone want a brand new unused 62mm throttle body!!! Link to comment Share on other sites More sharing options...
jonnyfox Posted September 23, 2012 Share Posted September 23, 2012 62mm! You need a man's throttle body fool, 85mm lol.....every mm counts............ ;-) Link to comment Share on other sites More sharing options...
stockhome Posted September 24, 2012 Share Posted September 24, 2012 I have a measily 48mm I think you two are compensating for something ;-) Link to comment Share on other sites More sharing options...
MrSimba Posted September 24, 2012 Author Share Posted September 24, 2012 85mm Jonny you nutter!!! I know of one 500bhp VX with a 62mm so fair to say its not a restriction!!! Anyway only selling the unused bling 62mm (sob!) as have to go cable throttle with the Adaptronics ECU, thats a 64mm so maybe Sheldons right....!!! Link to comment Share on other sites More sharing options...
Dr H Posted September 24, 2012 Share Posted September 24, 2012 Oooohh, can I join the contest I have a 70mm ready to go on the S2, Link to comment Share on other sites More sharing options...
DJWilma Posted September 25, 2012 Share Posted September 25, 2012 Oooh liking the chimney, where did you get this from or was it custom made ? Also only using a 56mm TB, but 400bhp wont be a problem Link to comment Share on other sites More sharing options...
MrSimba Posted September 25, 2012 Author Share Posted September 25, 2012 Custom made from B&Q alloy! Link to comment Share on other sites More sharing options...
