Hi All,
Does anyone have an opinion on this:
After having my wheel refurbished and new tyres fitted I have a noise that can only be described as rubbing two pieces of sand paper together coming from the front passenger side....but touch the brakes and it stops.
I have checked the new weights and they don't touch the wheel-I've been advised to have new discs and pads on but I'm more curious as to what has caused this!!
Any ideas welcomed :-)
Noisy Brakes?
Started by willgriffin1983, Jul 06 2012 08:23 PM
4 replies to this topic
#1
Posted 06 July 2012 - 08:23 PM
#2
Posted 06 July 2012 - 08:32 PM
The only noise I can think about that would be similar would come if the discs were rusty, but that wouldn't last very long and you'd be able to see the rust.
#3
Posted 06 July 2012 - 08:49 PM
Good chance its the pads making the noise. remove the front wheels and check for any marks on the inside faces. then remove the front pads, clean everthing up. Make sure the sliders are moving ok and put it back together and try again.
Ready for some summer rumbling :-)
#4
Posted 07 July 2012 - 08:18 AM
By precaution, check the wheel doesn't rub on the brake line. I had that and it was'nt good...
Check the dust guard too, mine did some noises, the dust guard was touching the disc...
#5
Posted 13 August 2012 - 08:22 AM
Thanks guys....took it all apart and then replaced the pads, problem solved! One of the dust guards was a bit close but not touching so sorted that at the same time.
While it was jacked up and wheels off thought it was an opportune moment spray some AFC 50 around ;-D
Thanks again!!
Thanks again!!
View Garage
