Urgent Help Needed!
yatesy
Hello all.
On my s1 elise I have a electrical problem....
After I have turned off the engine and removed the keys the lights stay on, they also flash, the revs and speed backlights, and the digital screen, the lights come on intermitenly and are causing the battery to go flat....
Any advice would be great.
Thanks
Yatesy
  • Replies 9
So you're saying when the light switch is OFF the lights come on by themselves or just dont turn off? If they dont turn off properly then I'd say faulty switch or sticking relay.
Hi phil
The headlights are off, the keys are out the ignition, but the backlights to the stack stay on, and flash, the small digital pannel ie: temp , fuel etc also stay on, this is after the keys are removed, doors locked and alarm set!!
Hi phil
When you say backlights do you mean rear lights (outside the car) or the bac klight to the stack dash or both?
Hi phil
Hey phil
Back lights to the stack mate
Your cigarette lighter is wired up wrong (Have you removed it recently? Swap the wires around)... :)
Although that solution is for when you have the lights on and tuen the ignition off the car keeps running, so maybe I am wrong?
Ha you beat me to it Dan. Just looking through the diagrams and the feed splits off from the sidelights to the dash and lighter. like you say having those wires wrong will give it a permenent 12V
I have not touched the cigarette lighter at all. Thanks for the advice though
