The kit comes with a sheet of Nimbus heat shielding, Stark also provide you with a template that can be used to cut the sheet out.
I personally used a combination of the template and measurements that I took myself, although I don't think this is absolutely necessary.
I used a marker pen to detail out the cutting lines and by using a tin cutter, traced out and removed the shape.
I also decided to create a cup to go over the toe link to give them a little bit more protection from the heat. This will only be secured on one side so that it can be bent out of the way for toe-link changes.
Pushed it into place for a quick check, before deciding where to drill for the rivets...
After I was happy with the location, I then drilled a number of holes to receive rivets and washers in securing the shielding into place. 30 Minutes later, I ended up with this...
I am pretty happy with that
One more job to do. Cut a little piece and secure it to on the engine bay side of the rear clam. I will bend this into place once the clam is back on the car. It will form a 'cup' over the exhaust manifold.
Happy with that. Job done!
